Arlo Pro 3 Floodlight Charging icon/
Why does one of my Arlo Pro 3 Floodlight cams have an orange charging icon and on my other Arlo Pro 3 Floodlight Cam the charging icon is green. They both are fully charged at 100% The backyard left is plugged in currently. The same with the backyard right.
Are you using the Arlo outdoor charger?
Yes
@Truth2121 wrote:
Yes
The VMA5600C?
Yes
If you swap chargers, does the problem move with the charger or does it stay with the camera?
One thing I figured out is when I am not using the magnetic cable charger, the battery icon will turn orange and the camera will not work while it is being charged. So I bought another 25 foot outdoor magnetic charger from Arlo. Hopefully the magnetic charger I was using will be the problem. I will know once I received the new outdoor charger.
