  • 6 Replies
  • 1260 Views
Truth2121
Why does one of my Arlo Pro 3 Floodlight cams have an orange charging icon and on my other Arlo Pro 3 Floodlight Cam the charging icon is green.  They both are fully charged at 100%  The backyard left is plugged in currently.  The same with the backyard right.
6 REPLIES 6
Are you using the Arlo outdoor charger?
Truth2121
Yes
@Truth2121 wrote:
Yes
The VMA5600C?
Truth2121
Yes
If you swap chargers, does the problem move with the charger or does it stay with the camera?
Truth2121
One thing I figured out is when I am not using the magnetic cable charger, the battery icon will turn orange and the camera will not work while it is being charged.  So I bought another 25 foot outdoor magnetic charger from Arlo.  Hopefully the magnetic charger I was using will be the problem.  I will know once I received the new outdoor charger.
  • 6 Replies
  • 1261 Views
