Arlo Pro 3 Constantly Recording After Firmware Update (1.080.14.0_654_e50ddf2)
  • 817 Views
Spanners
Hi All,
My Arlo Pro 3 cameras recently updated to the latest firmware 1.080.14.0_654_e50ddf2.
Since then, the cameras are constantly recording all the time even though there is no trigger.  Things I tried:
- I turned audio detection off and same issue.
- I removed the device and readded it.
- I reduced the motion sensitivity
I also have 6 Pro 2 cameras that are working correctly on the same base.
Is this a known issue with this firmware update?  Any ideas of what else to try to fix my cameras?
Thank you,
Try a hardware reset:
  • remove a Pro 3 camera from the account
  • open the housing and press the button inside until the LED flashes amber (~15 seconds)
  • add the camera back
If that resolves it, then repeat the process with the other Pro 3 cameras.
Spanners
Thank you StephenB.  I have done this and now doing some testing.
Edinburgh_lad1
Hero
Hero
Oh wow, that's actually a great thing to have, especially that you have to pay £13 per month to have it and you're getting it for free.
  • 818 Views
