Arlo Pro 3 Connectivity
  • 2 Replies
  • 1511 Views
mandy54
I just bought a set of three cameras with their hub. The cameras are only 40 ft away from hub, but still they have very low connectivity with the hub. The wireless connection is orange with only one line. This is brand new and it is supposed to work up to 300 ft away. What can be wrong?
What is in between the hub and the cameras?
Are you seeing lost connections when you try to live stream?
brh
@mandy54
The 300 feet distance is under ideal conditions with no walls, etc. between the hub and the cameras. Different building materials, the number of walls or obstacles between the hub and the cameras, how crowded your router channel, interference from other devices, etc. all have a bearing on how far you can place the cameras away from the hub. Generally, I would say that 50 to 60 feet is normal. Try moving your hub higher and closer to windows, or in a location with less walls between the hub and cameras.
Brian
  • 2 Replies
  • 1512 Views
