Arlo Pro 3: Cannot Disable Microphone
  • 31 Replies
  • 12693 Views
  • 8 In Conversation
MrBluesky
I have the problem that the device is still recording and sending audio to the cloud, despite being disabled in the settings of the camera.
I tried changing the settings in Android and Web, but both don't do anything.
Anyone has a solution? Is this a bug?
31 REPLIES 31
MrBluesky,
What settings are you referring to?
To disable audio, the microphone on the camera must be turned off. This can be found in the app under Settings > My Devices > select your Pro 3 camera > Audio Settings > Microphone toggle off
michaelkenward
Sensei Sensei
Sensei
There is a difference between using audio triggers to initiate a rule (If Audio is detected) and using the audio on the device itself.
Do you have a mode that has audio triggers?
Just another user
MrBluesky
Hi JamesC
Thank you
To more precise, in the DVR Modus, where the camera is always recording, can this be diabled too?
The setting you mention does disable it in the armed mode caught moments in the library
@MrBluesky wrote:
Hi JamesC
Thank you
@JamesC 's settings should disable audio in all modes (and in live streaming).  If it doesn't, then IMO it is a serious bug - in some situations it's legally important that audio be completely disabled.
MrBluesky
Hi James
I will check again when I'm back home and give you feedback.
MrBluesky
Hi Steven
I checked. It is as follows:
Camera is connected to the power and has DVR enabled. Audio and Mic is turned off
-> sound is recorded and played in live mode, in timeline and Library
Camera is NOT connected to the power and therefore DVR is disabled (but not turned off in options.) Audio and Mic is turned off
-> sound is NOT recorded and played in live mode and Library
So it seems that there is a issue with the DVR mode. In both modes I get a warning on android (when I try to enable the mic), that both are turned off, so the settings are set properly.
Hardware: H9, Firmware 1.060.10.12_358_e212922
This sounds like a bug to me.  BTW, I am thinking you mean CVR (continuous video recording). when you say "DVR mode".
@JamesC - can you escalate?
I've tested this as you describe and could not reproduce audio being recording in the timeline for CVR, library recordings, or live streams when the mic is disabled in camera settings.
Reboot your SmartHub and check again to be sure the mic is disabled in your camera settings.
MrBluesky
James,
I rebooted the basestation, removed the batteries from the cameras, still the same.
This has been escalated to the development team for further investigation. I will provide an update when I have more information.
StanWfromNC
Is there any resolution to this issue?
petevec
Unable to disable microphone audio function using Arlo app or Arlo web-based. The update firmware March 2020 and up-to-date firmware on app no avail.
petevec
Disabled microphone function still recording audio Arlo Pro 3
Jasta
Same here! The mic can be turned off in audio settings of the camera but still sound is recorded and uploaded to the cloud. This is a serious data privacy issue that needs immediate correction!!
michaelkenward
Sensei Sensei
Sensei
Turning off the microphone in audio settings does not disable recordings triggered by sounds.
Check also that your rules are not set up so that cameras Record video when Audio is detected.
From your description it isn't clear to me if you have done that.
Just another user
Jasta
Valid question, thanks! However, audio detection is turned off. Still sound is recorded. This definitely looks like a bug. Can you please fix it?
If it helps, I am available for a phone call..
michaelkenward
Sensei Sensei
Sensei
No. Please read my messages in their entirety.
By all means tell me how I can make my status even more obvious.
In essence, this place is mostly user to user.  There are other places for official support.
Just another user
Jasta
I am sorry, I have missed this point! Your message sounded so professional 🙂
But I have seen some Community Managers here.. maybe they can help. I will also contact the official support staff.
petevec
Problem solved. Initially was unable to disable audio feature on Arlo Pro 3. Previous solution was to tape over microphone hole. Reinstall Arlo app working as intended.
K80Shooter
Virtuoso
Virtuoso
Mine also records sound with everything turned off/ box's unchecked. I have not reinstalled software on my phone though I have deleted all cameras and reinstalled them and have reset the base/hub.
Jasta
And that worked for you?
K80Shooter
Virtuoso
Virtuoso
@Jasta
If you're asking me,  no nothing has worked. I will try deleting the app on my phone and reinstalling it today. I'll post back if that does the trick.
K80Shooter,
Did reinstalling the app work?
petevec
Problem solved. Reinstalled application, Arlo pro3 microphone function now working properly.
  • 31 Replies
  • 12693 Views
  • 8 In Conversation
