This issue is resolved in the latest version of the Arlo mobile app for iOS. Please update to the latest version available from the app store and test again.
Thank you,
Just tried it here with the Android app and it worked fine - there was a slider presented to turn it off. Maybe reboot the phone and reinstall the app?
elind1010,
Which version of the Arlo mobile app are you using and for what model device?
Hasn’t worked since the latest arlo update on the 8th
@elind1010 wrote:
iphone pro 12 max, 14.7.1
Hasn’t worked since the latest apple update
JamesC also asked what version Arlo App do you have. The lasted version is 3.5 for IOS.
elind1010,
This issue appears to be new to mobile app version 3.5 for iOS. The development team is currently investigating these reports. As soon as I have more information, I will provide an update.
Thank you,
@elind1010 wrote:
I have the latest version. I do not see any updates for Arlo. What date is this update?
It is IOS 3.5.1 released today. Uninstall the App and reinstalling it should give you the latest. It sometimes takes a while to show up in daily updates so you may have not seen it there.
