Arlo Hub wont connect to WiFi
Just got a new sb8200 arris modem with nest router. I can’t get my hub for the cameras to connect to it. It detects the WiFi but says something about mesh system. It’s a dual band router so it has the 2.4ghz and 5ghz automatically. How can I fix this so I can have my cameras work again. They worked fine on my old slower system
Are you still needing assistance or are your cameras now working?
No one has been able to assist me with this issue yet.
Are you seeing the smarthub listed in the router's attached device list?
