My Arlo base station continuously blinks orange. I have tried to reset/reconnect. When I press the reset button in the back, the light does change to blue but then seconds later, it blinks orange again. Will not connect.
It's not a matter of just pressing the reset button - it has to be held for >15 seconds until the LED starts flashing amber. Since you're trying to reset, all devices in your account must also be removed before trying to set things back up as if new.
