Any way to turn off motion notifications for only Pro 3 camera?
I’ve got one of my cameras mounted in the house I just want to use it as a live view camera, is there a way to turn the notifications off ONLY for that camera?
Thanks in advance
Best answers
Yes, you just have to modify the mode to disable notifications for that camera. It's best to create a new custom mode for this. Note you can delete the rule from the camera altogether if you never want recordings (which are different from notifications). https://kb.arlo.com/42/What-are-modes-and-rules-and-how-does-Arlo-use-them
@azteca wrote:I’ve got one of my cameras mounted in the house I just want to use it as a live view camera, is there a way to turn the notifications off ONLY for that camera?
Thanks in advanceYes in your Rules for that cam you can unselect recording and select "Do nothing". You can also turn off just notifications if you still want recordings.
Thanks in advance
thank you very much I greatly appreciated.
