Retired_Member
Not applicable
2025-02-03
02:23 PM
Hello - I need to update the email address for the account owner because the email address is no longer in use. How do I do this?
I would be more than happy to have someone look into this for you. Can you please dm me a callback number as well as a good number to call. That way I can have support look into this further. You send a dm by clicking on the envelope icon on the top right of the forum page.If you don't see it, then go into your profile settings and select preferences, then "Private Messenger." Then select "Turn on private messages" if it is turned off.
