- English
- Floodlights
- Arlo Pro 3 Floodlight
- pro 3 flood light is paired but will not stream an...
pro 3 flood light is paired but will not stream any footage. Blue light flashes on and off slowly t
Shows that its paired to my home wifi with blinking blue light then a rapid amber light flashez repeatedly znd turns off. Im wondering if I have enough wifi service. I think i have 50 mgb/s. I only have 2 tvs that use internet both turned off, my cell phone and the 2 security cameras(pro 3 flood lights). 1 flood light is paired the other will show paired but not stream video.
Rapid amber blinking when pairing means it did NOT pair. That's a fault indication. If you see it in Settings, My Devices, remove it there and try pairing again.
