- English
- Floodlights
- Arlo Pro 3 Floodlight
- automation feature of new app doesn’t work consist...
automation feature of new app doesn’t work consistently
The automation of new app doesn’t work all the time. I set sunrise to ARM Standby and sunset to ARM. Some days it works and some days it doesn’t work. Does anyone experience the issue?
The old app works all the time.
@sifuG wrote:The automation of new app doesn’t work all the time. I set sunrise to ARM Standby and sunset to ARM. Some days it works and some days it doesn’t work. Does anyone experience the issue?
It's been working fine here.
I have not been using sunrise and sunset as trigger though. Instead, I have been specific with "11:30pm every day", "7am Mon thru Fri", "7:30am Sat" and "6:30am Sun" --- they are all scheduled correctly.
I must say, though, that the "correctly" above has changed a little bit, but not to a disastrous level.
In the past (say up to 2 months ago?), these time scheduling were all correct up to the minute -- for both the notification and the mode change. Now, I am see the notification coming say late by 2-3 minutes sometimes. Not a show stopper to me, but definitely something different.
So essentially, time-scheduled routines NEVER fail me, vs what you reported here.
Alex
