Want to turn floodlight lights on/off via Alexa
I’m trying to figure out if I can use my Alexa to turn the lights on my floodlights manually on via a voice command. Alexa sees my floodlights as cameras - and I can watch the feed. But it doesn’t seem to understand they are lights too - am I missing something?
Hi @Dgiambal
Thank you for the feedback regarding this, I'll have my team look into this and I'll report back with more info as soon as possible.
Thanks. Any updates on this?
Hi @Dgiambal
Thank you for your patience while I investigated this. At this time only the (Security Light) Al1101 is compatible with this feature/command. I have provided this request as an enhancement for future consideration.
https://www.arlo.com/en-us/support/products/arlo-security-light.html
Arlo Pro 3 Floodlight
