- English
- Floodlights
- Arlo Pro 3 Floodlight
- Solar Panel Charger for Ultra, Pro 3, Pro 4, Pro 5...
Solar Panel Charger for Ultra, Pro 3, Pro 4, Pro 5, Go 2 & Floodlight Cameras Question
I have an Arlo Floodlight 3 and recently purchased a solar panel (Solar Panel Charger for Ultra, Pro 3, Pro 4, Pro 5, Go 2 & Floodlight - VMA5600-20000S) to charge it.
It worked for one day and now I get the below error message when trying to charge it:
"Unable to charge Battery.
Connect a compatible Arlo Charge to the device to charge"
I have reset the device but no change.
I believe that message usually means a connection problem between the panel and camera. Have you tried cleaning the connection on both sides?
