  • 4497 Views
MarkHodg
Hi,
My pro 3 floodlight camera housing and Wall mount have cracked after just a few months. Does anyone know if it is possible to buy replacement ones?
I'm loathe to buy a new camera when it is the mount and outer case that have gone.
Thanks in advance
dcfox1
I don't think you can buy a housing but wall mounts are available on Arlo's Accessory page. Some third party mounts may work but not sure with the Pro3 Floodlight.
MarkHodg
Yep, that's what I've found so far which isn't great for a £200 light with a rather flimsy bracket.
You could contact support and RMA the camera.
  • 4498 Views
