- English
- Floodlights
- Arlo Pro 3 Floodlight
- Pro 3 floodlights turn on when entering schedule m...
Pro 3 floodlights turn on when entering schedule mode
Arlo Pro 3 lights and cameras all come on at the same time when they enter schedule mode. I’ve redone the schedule, deleted and recreated the rules. And even did a factory reset on the base station but nothing prevents them from turning on when they enter schedule mode. Really frustrating. Is this an issue that needs a test firmware (?) also?
Didn't you state in another thread (PLEASE just use one thread per issue!) that you had resolved the issue by changing the schedule to activate 2 minutes later?
I'm sorry, yes I did. But as soon as I did, the problem reoccurred the following night. I ran across ShanyeS thread and decided to pursue it there. Sorry for the confusion. I'll keep one problem to one thread.
On another note, since the problem reoccurred, I adjusted the motion and audio sensitivity from 100% down to 75% and I think it's working as of last night. We'll see as time goes on. Thank you.
