Help! My camera works fine with notification too.
But the floodlight does not activate with the same motions that alert me and the camera. When I activate the floodlight button, it does light up. But not when motion is detected by the camera.
Please help and thanks, Max
It sounds like a settings problem.
Do you see "Library" in your app menu? Or do you instead see "Feed" and "Dashboard"?
Arlo Pro 3 Floodlight
