Pro 3 floodlight light never stays on for more than 30 seconds.
  • 6 Replies
  • 4436 Views
  • 2 Likes
GuyMV
Pro 3 floodlight paired to VM 5000 base. I’ve set the light duration to both 5 and 10 minute operation, but the light never stays on for more than 30 seconds. Ideas?
GuyMV,
The floodlight will remain on for the duration of the motion detection rules you are using. Take a look at your mode and set up a custom mode or adjust the duration of the default Armed mode motion detection trigger. For more information on custom modes, take a look here: How do I create a mode with different rules for each Arlo Wire-Free or Arlo Pro Wire-Free camera?
6 REPLIES 6
Do you mean when motion is detected? That's a setting in your modes and rules.
GuyMV
Hi, and thanks for the reply, but no: it didn’t help. I’ve been through both options without change. I’ve begun to think it’s something to do with my SmartBase 5000, but haven’t had the time to investigate. I’ll reset the thing; if nothing changes, I’ll pair the floodlight back to my NETGEAR router and see what happens.
Thanks again.
T0mgl
What was the outcome, I have the same issue?
GuyMV
tl;dr no change.
With light duration set for 5 mins:
I rebooted base with floodlight paired: no change, light on <20 sec
Deleted floodlight, removed battery, rebooted base just because, paired floodlight and reinstalled battery: no change, light for <20 sec
Deleted floodlight, removed battery, paired floodlight to NETGEAR router, inserted battery: no change, light for <20 sec
I now assume it’s the floodlight. Any suggestions, anyone?
GuyMV,
GuyMV
Thanks, JamesC - I get that. My goal (and that of others, it seems) was to have the floodlight remain lit for x-minutes after detected motion, sound and recording stopped, as additional deterrence. After a deep dive through the many posts on this issue, I understand it isn’t possible, and the only “fix” is to lengthen the recording time to x-minutes to keep the light on.
  • 6 Replies
  • 4437 Views
  • 2 Likes
