Pro 3 connection to wifi
If you have special characters in the network name or password, you might try removing them.
Some wifi networks have settings that allow clients to reach the internet but block them from "seeing" each other. If you have any settings like that enabled, you need to disable them.
Standard Hitron modem from Shaw cable. I don’t suspect it prevents clients on the same network from talking.
@Mattward439 wrote:
SSID no special characters. Password no special characters.
Guest Networks often do this by default. But I'm not seeing this in the Hitron CODA-551x manual.
Of course Mac Address Filtering could prevent new clients from joining the Hitron. But I think you'd have already sorted that out if you use that feature.
Have you checked the attached device list in the Hitron after you hear the chime? Often the camera is able to join the wifi, but for some reason the Arlo app can't find it. It'd be helpful to know if that is your situation or not.
@Mattward439 wrote:
Yes, the Pro 3 Floodlight camera FB1001-A00BE shows up in the Hitron 2G wireless connected devices.
Ok. So the only missing step is that the app can't find the camera for some reason.
Unfortunately, there's no real solution to that problem. About all we can suggest is to try again. If the macbook is connected via wifi, then try connecting it with ethernet instead. That sometimes works when the app fails.
@Mattward439 wrote:
I added a Buffalo whr-300hp2d router to the LAN port of my Hitron. Mac wifi and Arlo setup set to 2.4G Buffalo network.
Interesting.
You could try disabling the Hitron wifi, and setting the Buffalo to use the same network name and password that the Hitron is using.
Then if you can onboard with the Buffalo, you can try turning it off and then re-enabling the Hitron, and see if the cameras still show up online.
@Mattward439 wrote:
FB1001 shows up Buffalo DHCP Clients but not in Wireless clients.
Do you mean it's not showing up in the Buffalo's list of wireless clients? Or that it isn't showing up on the Hitron?
@Mattward439 wrote:
I got the same results with Hitron modem and Buffalo modem. DHCP client but not Wireless client.
Not sure that is particularly relevant to the onboarding issue.
Tried to do the factory reset but it never flashes just 3 times Amber.
On trying to connect, it gets on the network (can see it on router, after removing it from the client list and doing up to the chime), but it just won't connect to the app.
My other cameras work fine, and this did until yesterday when I had to swap my router for a few hours and back.
lp77,
Make sure the camera is fully charged, attempt the factory reset again and then attempt to onboard. Do you experience the same issue?
My issue was different in the end. I was selecting arlo essential and not arlo essential floodlight (maybe needs to be a bit more obvious for a doofus like me)
Arlo Pro 3 Floodlight
