Pro 3 Floodlight
  • 9 Replies
  • 3276 Views
Dignan76
My previous case 42759539 was closed without resolution. My floodlight will still not be reset and it is not scanning the QR code to rejoin my network. I ensured I was on 2.4ghz wifi channel but the floodlight still will not connect. The reset process never actually gets me the amber light so it is not working. I have had the floodlight since June 2020 so it is out of warranty and seems like I am out over $300 since I also bought the charging cable. Seems like the floodlight broke forever right after the warranty period expired.
9 REPLIES 9
Have you tried removing/reinserting the battery before trying the reset?
Also, have you tried both the app and a PC browser (my.arlo.com).
Dignan76
Thanks for the suggestions. I did try removing the battery first and reinserting. I the light at the top above the camera never actually comes in. The light on the side of the camera just slow blinks blue.
I also just tried using my computer but it seems like the floodlight never goes into pairing mode.
Slow-blinking blue means the camera is in pairing mode.  https://kb.arlo.com/642/What-do-the-different-LED-behaviors-on-my-Arlo-camera-mean
When you add the device, are you choosing the Floodlight Pro 3 ( which is under "lights")?  Or the Pro 3?
Dignan76
It’s the pro 3 floodlight. The graphics for the floodlight show the blue light blinking above the camera which is not blinking for me. Only the blue light in the side is blinking.
The only status LED is on the right side of the camera (as you face it).  https://kb.arlo.com/000062381/Arlo-Pro-3-Floodlight-Camera-Product-Tour
Dignan76
Thanks for that. Regardless, I am getting a slow blue blink for that light and I never get the amber light when trying to reset by holding the sync button down.
Understood.
I was double-checking that when you added the device that you were telling the app/web UI that you were adding a Pro 3 Floodlight (not an ordinary Pro 3).
Dignan76
Still not working after trying all the suggestions. Starting to worry I’m out $300.
It could be that the sync button is defective. If it doesn't turn amber no matter how long you hold it, then you could contact support and ask for an RMA (assuming the camera is still under warranty).
  • 9 Replies
  • 3276 Views
