Pro 3 Floodlight Step Up flaws
Arlo Set Up is a very flawed process that last well beyond the 2 minute time out length of sync causing a failed setup or failed firmware status check which results in a failed network connection.
THE PROCESS IS TOO LONG
Arlo please fix this!!!!!!
Can’t post image to post as once again a failed process will not accept jpeg
Change the extension to jpg.
Extension?
It’s a screenshot via iPhone
@DjTeaze wrote:
Extension?
The file still has an extension (either .png or .jpeg). .png will work, .jpeg needs to be renamed to .jpg.
You need to copy the screenshot to a PC (or Mac).
Arlo should fix this - there's no reason the forum can't accept .jpeg.
Arlo Pro 3 Floodlight
