- English
- Floodlights
- Arlo Pro 3 Floodlight
- Only want floodlight to turn on when motion is det...
Only want floodlight to turn on when motion is detected.
- Does anyone no how to set up the Arlo Pro 3 floodlight to only turn on at night when it senses motion? Currently the light automatically turns on at dusk and stays on all night. I would prefer it only turn on when motion is detected.
@Haldini wrote:
- I would prefer it only turn on when motion is detected.
This is what it should be doing by default.
Have you changed any settings?
Did you perhaps get a CVR subscription?
Go to the camera settings and check Night Vision. You may need to change the ambient light sensitivity. If that doesn't help, try removing and reinstalling the camera.
