  • 2 Replies
  • 2261 Views
dtheo
On my Pro 3 Wire-Free Floodlight I no longer get color night videos. I am running Arlo iOS app version 4.5. Following the document “How do I adjust the light settings on my Arlo Pro 3 Floodlight Camera?” using the
Arlo Secure App experience with Library I see the following.
The settings in “Settings > My Devices > Arlo Pro 3 Floodlight Camera > Light Settings” don’t exist. However, there is a single switch called “Floodlight” that if I turn it on those settings do appear but also the light comes on manually right then and after 5 minutes the light turns off and the settings switch goes back to off.
FYI, The floodlight camera is directly connected to my WiFi, no SmartHub is involved.
Go into the mode for the camera, and look at the rule.
There should be a checkbox item "turn floodlight on" when motion is detected.  Make sure that box is checked.
dtheo
Thanks, I had the action in Arm Away which is scheduled for overnight but needed the action in Arm Home also since dark earlier.
  • 2 Replies
  • 2262 Views
