  • 1 Reply
  • 1345 Views
Vega18
new arlo floodlight. When it’s live stream and recoding it makes a beeping noise/screech. Any suggestions on how I can fix this issue? #arlofloodlight
If you are talking about the siren, then look in the rule for the camera, and see if the siren is enabled when motion is detected.
If that's not it, you likely have a defective camera.  You can just exchange with the seller, or try using phone support via the app.
  • 1 Reply
  • 1346 Views
