- English
- Floodlights
- Arlo Pro 3 Floodlight
- I lost powers in my house for 4 hours, floodlight ...
I lost powers in my house for 4 hours, floodlight now shows offline
I lost powers in my house for 4 hours. My Pro 3 floodlight now shows offline even though the power is back on. Any suggestions? I don’t want to take my camera off the mount to do this. Thanks
Unfortunately I think you will need to do that.
If you are using a base station, try restarting the base first. If that fails (or if you have no base), then I suggest starting by removing the battery in the camera and then reinserting it.
