Floodlight set to stay on longer than 120s
I know how to set the arlo floodlight to record fixed duration to keep the led on for 120s before it turns off. This is kind of dumb in my opinion. There should be an option to control the duration of the led seperately. I need the motion trigger to turn on led for longer than 5 minutes. Since this is not an option I will probably return the floodlight. Is there some schedule where you guys will update the firmware to support this. The 1-20minutes duration is completely useless unless I am home and on the app. Since mine is hardpower there is no need to worry about battery life. I see a few threads on this a while back and it doesn't look like you guys are interested to addressing this. I just need to know so I can return or wait for the update.
Thanks!
Mvly001,
There is no option to separate the duration of the floodlight and the recording duration at this time. I will pass your feedback along to the development team for consideration.
Arlo Pro 3 Floodlight
