Floodlight 3 receiving audio alerts
  • 177 Views
WD83
I am getting non-stop events. It says it's Audio, but there's nothing. It only started a few days ago after months of non-issues, and I have not changed anything. I reduced the audio sensitivity, but it's not making a difference.
Any ideas?
If you don't need audio detection, disable it in your modes and rules but leave motion detection enabled.
amy312james
That kind of sudden spike in false audio events usually points to interference or a firmware glitch rather than actual sound. Since lowering sensitivity didn’t help, try rebooting the device and base station, check for recent firmware updates, and if possible, reset and re‑add the device. Also make sure there aren’t new background noises (like appliances or HVAC) that the system might be misinterpreting.
^^ Sounds like an AI response to me.
  • 178 Views
