My flood light won't stop recording every other minute it will record a two minute video and continue to do so all day resulting in draining my battery.
Start by removing and reconnecting the camera in the app. If needed, take it into a dark room with no motion going on and see if it does the same thing. If so, swap at the store if possible or use the Contact Support link at the bottom here.
Arlo Pro 3 Floodlight
