Flood light charging
I recently purchased an Arlo Pro 3 floodlight for my building. I also purchased an extra battery for the camera due to the battery draining within less than a month of use. It is very disappointing that I have to remove the camera and charge the battery instead of having one battery charging while the other is in use. Is there a charging station or a better way to charge my floodlight? I have also purchased an outdoor cord but unfortunately I do not have an outlet in that section.
Yes, there's a charging station available - check the accessories here to find it. You could also potentially use the solar panel instead of AC power as long as you realize it's a trickle charger that can't keep up with heavy usage. Battery life is based on <5 minutes per day of recording and live view, on average.
Arlo Pro 3 Floodlight
