adhoyt,
The toggle switch will appear within live streams. This allows you to manually turn on the floodlight when live streaming.
If you want the floodlight to engage during motion detection events, this can be set up within your modes/rules. For more information on this, take a look here: How do I trigger the floodlight on my Arlo Pro 3 Floodlight Camera?
The "halo" effect you're seeing is due to the IR LEDs reflecting off the surrounding objects in your environment.
adhoyt,
adhoyt,
The toggle switch is located in the bottom right hand corner of the camera widget underneath the settings icon (gear).
