  • 5 Replies
  • 1199 Views
Jmpage80
I have tried everything multiple times .  I have full WiFi signal. It flashes blue then never connects. Then I keep doing the same process over and over.  This floodlight is junk .
5 REPLIES 5
Have you reset the camera?
https://kb.arlo.com/000062438/How-do-I-factory-reset-and-re-sync-my-Arlo-camera
What exactly have you tried and what do you see? Are you connecting to a hub or to your WiFi? WHat happens if closer to those?
Jmpage80
This company is horrible company.  I bought pro3 floodlights and haven't got them to work yet. But arlo has continued to steal money from my account by charging me subscription service charges for floodlights I cant get to work.  This is an absolute horrible company selling junk and stealing money from customers
Jmpage80
Floodlights scan the code from phone then it just shows circle . Never connects. This product is absolute junk and the company itself is horrible at customer service. I paid $500 for floodlights that don't work and have been charged for months for subscription charges for products I haven't been able to use
Jmpage80
Yes I reset them 30000 times.
Are you connecting to an Arlo hub or your home wifi?
If a hub, have you double-checked that it is compatible?
VMB3xxx hubs aren't compatible, VMB4xxxx or VMB5000 are.
If Home WiFi, then
  • Are you getting the chime when the camera reads the QR code?
  • Have you made sure the wifi security is WPA2 (AES)
A couple of things you might also try:
  • If you are using the app, then try a Windows PC (my.arlo.com).  That sometimes works when the app fails.
  • If you have punctuation, spaces, or other "special" characters in the wifi name or password, then try removing them.
  • 5 Replies
  • 1200 Views
