  • 1 Reply
  • 1677 Views
MichaelKenneth
I'm looking at the Arlo Pro 3 Floodlight and would like to replace an existing hardwired *real* floodlight.  Does this floodlight support normal outdoor fixture electrical installation?  ie hardwiring it and installing/mounting it to a proper outdoor electrical box?
I was looking at the pictures and it looks like it doesn't, but wanted to confirm.  In part of the description it says it can be wired, but I'm guessing that means via a magnetic charging cable.  If not, are there plans to make a proper 120v hardwired floodlight for installation in the future?
You can purchase the outdoor power supply to do this. You can't wire it like a normal light but you can power it using the Arlo accessories. Check the accessories for the floodlight from the links at the top here.
  • 1 Reply
  • 1678 Views
