Using Samsung A51 with December 9 2022 update of Android app with Arlo Pro 3 Floodlight.
Once the siren is activated, I do not get a slider at the top of the Devices page to turn it off as per instruction manual.
The iPhone app manual siren operation is also different to the tech manual.
It has changed to now being a red screen with the slider at the bottom.
Not sure if the android does the same now or is again something different with the new automation app update recently released.
Can you tap on the shield icon again to disable the activated siren?
Does this happen when you manually trigger the siren from within the app or when a camera is causing the trigger,
Yes. When I manually trigger the siren in the app.
