Can’t Sync and can’t reset
Hi
I got the new floodlight.I tried to sync but can’t, and also can’t factory reset.
Now, the device is flashing the blue light flashing on around 10 seconds intervals.
I also heard small sound light turning on/off the camera when every blue light on.
Any advise please?
I suspect it's a faulty camera. The fastest solution is to swap at the store.
Arlo Pro 3 Floodlight
