Battery died in security light and now strobes
@Glackowitz wrote:
Battery died in security light and now it wants to strobe when a full battery is inserted or plugged into charge cable. Has been working fine until now. Any way to reset or is it junked and toss it?
Did you check the flash setting?
If it is set to "off", try setting it to "fast" or "slow", and then set it back.
@Glackowitz wrote:
Can’t get to settings as it’s offline since battery died. The second power is applied via battery or charge cord it starts strobing. It’s a fast strobe…3-4 flashes a second non stop until power is removed
I suggest charging it back up, and then check the settings.
You might also need to remove the light from your account and set it up again (which I know is a pain).
Glackowitz,
Try factory resetting your floodlight and then add it back to your account and test to see if you still experience the same behavior.
You can factory reset by pressing and holding the sync button until the LED flashes amber and the camera reboots. After the reset, setup the camera using the Arlo mobile app as if it were new.
This appears to be the original Arlo Light, not the newer Pro 3 Floodlight.
I've seen info on how to reset the Arlo Bridge, but nothing on how to reset the light.
Arlo Pro 3 Floodlight
