  • 5 Replies
  • 1200 Views
Flash2021
I have this setup to local storage hooked to base unit but now all of a sudden it stopped recording events. I know it probably coincides with subscription end but I thought it would continue to local storage. Any help would be appreciated.
5 REPLIES 5
It does.  What base do you have?
Flash2021
Vmb4500r2
@Flash2021 wrote:
Vmb4500r2
With that base, you need to eject the USB storage, and connect it to a PC to view the recordings.  Have you tried that? (I realize that the screenshot shows 0 GB used, but I think it is worth checking manually).
Of course the camera also needs to be paired to the base (not connected to home wifi).
Flash2021
I checked it and it is recording to local storage but my other Arlo cameras still show it in the app. I guess my Arlo doorbell will disappear too when free trial is up.
You are only seeing cloud recordings in the app.   There is 7-day free cloud recording for the older Arlo cameras (for example Pro, Pro 2), but not for the newer ones (starting with the Ultra in 2018).  So you will lose cloud recordings for the video doorbell when the trial ends.
If you are wanting direct access to local storage in the app, then you need a smarthub (VMB4540 or VMB5000).  https://kb.arlo.com/000062337/What-is-Direct-Storage-Access-and-how-do-I-use-it
There are some limitations:
  • Recordings only available in the app (not the browser)
  • Recordings only available in the primary account (not friend accounts)
  • No manual recordings of video or snapshots
  • No Thumbnails
  • Remote access requires either port forwarding or a VPN (both requiring router configuration) - which some find difficult.
  • 5 Replies
  • 1201 Views
