I was very excited to purchase my floodlight cam. I am on the 3 month trial. My issue is the latency from the cam. Almost 30 second delay from motion to my iPhone. My older arlo cams had their own hub and the speed was 1-2 seconds. So can you tell me how to fix this issue. I would like to see people approaching my house in real time so I can use the speaker function Do I need to purchase a new hub ?
Greaza,
A delay is expected for content to reach your library as the it will only arrive in your library when recording has finished. You can reduce this time by adjusting the recording length to be shorter: How do I adjust Arlo video recording length?
Do the shorted recordings happen on every video? Are you sure you saved your settings?
Arlo Pro 3 Floodlight
