Arlo Pro 3 spotlight not connecting to app.
Received the Pro 3 Floodlight recently. Have been trying to get the app to find it to no avail. I have taken the battery out/back in. I have hit the reset button numerous times. The floodlight does read the QR code, but that's it. My wireless setup is through a Google wifi router.
Thanks for the assist.
Are you selecting "Cameras"?
Or are you selecting "Lights" and then the "Pro 3 Floodlight"?
Also, define "hit the reset button". You don't just press it, you have to hold it for >15 seconds.
Thanks for the reply. I am selecting "lights" and then Pro 3 Floodlight.
As far as the reset, pressing the small button below the camera for about 15 seconds until the amber light comes on.
ok.
I suggest trying to on-board with a PC instead of the app (browse to my.arlo.com).
Thanks for the recommendation. When I attempt to go to the site, they are asking to subscribe to Arlo secure. I click on "Subscribe Now", it tells me I have to have a camera first. I'm thinking I may just have to send this camera back for a refund and try a different brand.
You have to dismiss that screen.
Arlo Pro 3 Floodlight
