I see this has been posted before but don’t see any resolve. Constant white noise, both live and saved videos. I’m unable to upload a video to show.
Please reach out to the Support Team to further investigate this issue you are experiencing. You can find several options for contacting support though the Arlo Mobile App by navigating to Settings/System/Support.
Pro 3 Floodlight Terrible crackling noises interfere with hearing communications all the time and miss recordings. When paying for continual recording, it shouldn’t happen. Going on 2 years now -they’re not going to fix it, sadly.
Hi @Cofeeh Are you using the iOS or Android app?
iOS
Can you download the latest version of iOS 4.7.1 and test again? If you do not see the update you can remove and re-install the Arlo app to force the update.
Still not working.
I’ve moved so I’m temporarily not using them. But when I last used them 3 weeks ago, yes.
Someone emailed me from Arlo, how can I confirm it’s someone that actually works at Arlo?
A start is to expand the to/from/subject section to see if it's really from Arlo (would come from arlo.com). Hovering over that section on a computer may also show you what you need.
@Cofeeh You can send me the details and I can verify for you, it was likely a member of my support team reaching out to check on you.
Arlo Pro 3 Floodlight
