I set up the Arlo Pro 3 Floodlight; everything works well so far except when you trigger, and the floodlight comes on at night in ARM mode, the light will not stay on pass 20 secs. Is there a way to increase this time to like 5 or 10 mins? The manually option to turn on the floodlight works and will stay on for the time specified.
Only way I know is to set the mode so that the camera records motion for 2 mins fixed length.
The other option is "record max of 5 mins or until motion stops", sadly by the time most motion stops I still want the light on, so I just go with 2 mins as the default recording mode which keeps light on for 2 mins.
The light should stay on for the period of recording selected in your modes and rules. What mode are you using, the default Armed mode or a custom one? Have you changed the recording length setting?
