Arlo Pro 3 Floodlight recording audio constantly
  • 574 Views
Djeunggolf
I saw a similar post about this camera constantly recording audio, even when “Audio Detected” is set to OFF. Has there been any provided solution to this issue? I’ve looked everywhere for a solution, with no success.
Do you have CO/Smoke detection enabled in the smart notifications?
Djeunggolf
I’m not following. My exterior camera doesn’t have a smoke/ CO detector. How would this sort of notification cause my camera to constantly record audio? Can you elaborate so I might understand?
The CO/Smoke detector option in Arlo cameras is listening for the chirps from a nearby smoke detector.  Some have reported that enabling that feature triggers your symptoms, so it is a good thing to check before moving on to the next step (which would be a factory reset).
  • 575 Views
