Arlo Camera Light only stays on for 10 seconds??
I've read the admin post that this issue was solved but based on the posts by consumers, it's clearly not solved. Arlo needs to push through software updates through its App to fix this problem. There is no way to adjust the Light Settings - the light always shuts off after 10 seconds. WT? This is a simple problem to fix.
Considering going with another company and posting negative reviews.
The light turns off when the recording stops. And you can set the length of the recording - either to a longer fixed time, or "until motion stops".
You do this by editing the rule for the floodlight in the operating mode (likely you are using the armed mode). https://kb.arlo.com/42/What-are-modes-and-rules-and-how-does-Arlo-use-them
Arlo Pro 3 Floodlight
