I have a vmb4000 and already 4 cameras for free. I was wondering if adding a floodlight camera and a doorbell would be possible without getting a subscription or would I have to pick just one. Thanks for any help
The Pro2 and older are still free for cloud recording for 7 days but the Pro3 Floodlight and Doorbell will need a sub for cloud after the trial to smart runs out. You can connect them them to the base for local storage if you want that but not as ideal as cloud storage. If you connect them to your wifi network and not the base you would need a sub for any recordings.
Arlo Pro 3 Floodlight
