rubber cover for USB port on the back of my Pro 2 came out
The rubber cover for the USB port on the back of my Pro 2 came out of the slot. How can you insert the end piece back into the slot? Any ideas? The piece wants to stick out when I cover the USB port.
IIRC, I was able to replace the cap by using a small instrument to push the retaining strap back into place. Takes time and effort with small tools.
Thanks. I tried what you suggested and it worked!
