Can I recover some videos that I accidentally deleted yesterday? It claims to provide cloud storage. Does Arlo have a cloud?
The reply has nothing to do with Arlo and has been reported.
The only way to preserve videos is to set up local recordings. This requires connecting all cameras to a hub as well as installing and configuring a USB drive or SD card, depending on your choice of hub. Deleted videos from the cloud are not recoverable but would still be available using local recordings.
The fact that you're posting in the Pro 2 section means you have an older base (unless you've replaced it). You can set up local recordings on a VMB4xxx base but will need to eject the drive for viewing on a computer. The newer SmartHubs support using the app to directly view those recordings so contemplate upgrading to one of those. The earliest bases (VMB3xxx) don't support local recordings at all.
So, no, you can't get those videos back.
