pro 2 cable question
  • 2 Replies
  • 2495 Views
pstoric83
Looking into the pro 2 for my front door. It would be under the overhang so it woudn't get wet but I've seen it has many issue with the power cable from Netgear which seems a bit crazy. I see on amazon I can get longer 3rd party cable but wanted to post here to see what owners recommend that have the pro 2 (wired) outdoors. Anything else I should be worried about?
As you prob know, the outdoor weatherproof ac supply has been recalled by Netgear. A new one has not been anounced yet.
As to using the indoor adapter in an outdoor situation... it isn't weather proof nor does it have the built in o-rings on the usb plug to prevent water intrusion. Netgear will not support any warranty claims if it is use ( nor prob 3rd party accessories ) as such.
But some have done it and have sealed up the cameras with silcon... just be aware of above before going outside the box.
I find the battery to run a few months so have not needed the ac supply outdoors
Johnny290
Mentor
Mentor
Been using this for months no problems Amazon Pangda
4.2 out of 5 stars 29 Reviews
Pangda 20 ft Weatherproof Cable for Arlo Pro, Arlo Pro 2, Aluminium Alloy Micro USB Cable, 1 Pack (White) the chager is indoors the cameras are outdoors
  • 2 Replies
  • 2495 Views
