  • 4324 Views
lisaJ
Hi,
Have a Warehouse area which is 2 levels and a workshop with 2 seprate areas. I need coverage in all areas - some will be exposed to the weather. While others will be under cover. Please recommend the best product.
steve_t
Master Master
Is there power available at the locations you want the cameras? Is there an ethernet point in the center of each level? Is there wifi throughout the premises?
I'd suggest the Arlo Pro 2 system with AC power to the cameras if possible. You may want 2 base stations to give adequate coverage but they can both be on the same account or on different accounts if you want
lisaJ
Yes we have power to all sites but would like it to be wireless. Our wireless system is not very good - always dropping out. Is there any way of getting a quote done ?
steve_t
Master Master
A quote? This is consumer DIY equipment so you'll just have to shop around for what you want/need
  • 4325 Views
