I need to buy a new power adapter for Alo Pro 2. can anyone tell me if this is the correct one? it is from Amazon.
Thank you
Arlo Accessory - Outdoor Power Adapter | No charging needed | Compatible with Pro, Pro 2 | (VMA4900)
That is the outdoor adapter. For normal use, you probably want the VMA4800, which is $10 cheaper
https://www.arlo.com/en-us/products/arlo-pro/power-cable-and-adapter.aspx#VMA4800
The indoor looks to be Currently unavailable maybe you can get it somewhere else.
Arlo Accessory - Indoor Power Adapter | No charging needed | Compatible with Pro, Pro 2 | (VMA4800)
If You Got Em....I'll Chew Em!
Netgear & Arlo Beta Tester
