how do I get the motion sensor to narrow its field of vision
  • 1 Reply
  • 1076 Views
flemingfence
You can't. The PIR sensors cover the whole range and can't be modified. However, if plugged into power, you can set zones which then use pixel detection to determine if the movement was outside of the zone.
  • 1 Reply
  • 1077 Views
