  • 1 Reply
  • 1299 Views
pino4567
I have 4 Arlo cameras. I believe they are Pro 2 models. I pay a monthly plan for the Arlo Secure Plus Elite plan that gives me recordings for motion detection. But, how do I get a plan that will allow me to record 24/7 without needing it to record after a motion detection? If I notice that something happened in my yard that wasn't detected by the motion sensor, how can I go pull up a time frame period where I can see what happened during that time frame?
That would be the CVR (continuous video recording) subscription.
That would cost you about $25 USD per month for four cameras.  You would also have to power them from AC power, since CVR uses too much power to be available on battery.
If you are still interested, verify your camera model first.  Open the case and remove the battery(s).  You'll find a label inside that starts with VMC.  Make sure that model is on the list of cameras in the above article.
  • 1 Reply
  • 1300 Views
